Re: 100 firing
Posted by Farmer Bob on August 21, 2004 at 21:04:16 from (67.5.118.163):
In Reply to: 100 firing posted by JD Carter on August 21, 2004 at 16:24:24:
Make sure you don"t have the lead from the condensor shorting out on the distributor housing. It"s easy to get it out of place in those tight quarters you have to work in. My bet is you got a bum coil. Make sure,if the tractor is still 6 volts and positive ground, that the lead from the distributor is connected to the + terminal of the coil
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
