H belly pump and implement
Posted by haymeadow52 on August 22, 2004 at 18:40:28 from (12.26.62.76):
H belly pump has ND 30 weight motor oil, implement has a single acting cylinder to raise and was used with hydraulic fluid. I would like to continue using the ND 30 weight oil in the belly pump. Question is...do I need to drain all of the hydraulic fluid from the implement cylinder and hose, and if so, what is the recommended (easiest) way to do that? Or is it possible to just use it like it is and have the hyraulic oil mix with the ND 30 weight oil? Tractor will only be used with this implement. Thanks.
Post a Followup
Subject:
