Re: problems 560D
Posted by captaink on August 23, 2004 at 09:06:41 from (66.115.212.249):
In Reply to: problems 560D posted by Scotty on August 23, 2004 at 07:20:16:
Scotty, are you loosing anti-freeze from the cooling system, is it using any oil? How many hours do you have on the overhaul, and how was the engine broken in?
The 560 Diesel has dry sleeves, so the cracks in the sleeves are not where you were getting water in your oil, rather probably from the head. Another possibility is that the block may be cracked behind the dry sleeves, which could be a source of water in the oil.
How long are you holding your glow-plugs when you start the engine? Thirty to sixty seconds (is common), then continue to hold them and hit the starter. After it starts, hold the glow plugs in until the smoke clears or the engine starts to run smooth. Have you had the injector pump checked? The pump might not be putting enough pressure to the injectors under light loads to get a good spray pattern.
Good luck!
Post a Followup
Subject:
