Re: Farmall 400 Diesel won't move
Posted by El Toro on August 23, 2004 at 17:34:27 from (216.148.246.70):
In Reply to: Farmall 400 Diesel won't move posted by Braxton Fullerton on August 23, 2004 at 16:38:06:
Hi, Does the engine attempt to turn over? It may have a hydostatic lock due to coolant leakage
into the cylinders. I wouldn't pull it anymore until you check the engine to see if you can move it over by hand. The engine may be seized too since it hasn't been run in years. I would check that first. It may turn over hard, but you should
be able to rotate the engine. Good Luck, Hal
Post a Followup
Subject:
