Re: Farmall 400 Diesel won't move
Posted by El Toro on August 24, 2004 at 04:43:20 from (216.148.244.38):
In Reply to: Farmall 400 Diesel won't move posted by Braxton Fullerton on August 23, 2004 at 16:38:06:
Hi Braxton, Is the radiator still full on this
tractor? If it is still full and there has been
a cover over the exhaust pipe I would rule out a
hydrostatic lock. You may have to remove the injectors and squirt diesel fuel or transmission
fluid into the cylinders and let it soak for a few days. I would first use the pipe wrench as the one man has suggested. Once you get it broke loose then you can use the starter. Good Luck, Hal
Post a Followup
Subject:
