Farmall Distributor
Posted by Brian Schmidt on August 25, 2004 at 05:30:25 from (12.2.142.7):
I am working on a 450 Farmall. It has much slop in the distributor shaft where the points ride and the rotor fit on. You can open and close the points by moving the shaft. Are these rebuildable or do I need to find a different distributor?
Post a Followup
Subject:
