Re: Farmall Super A ? change 6 to 12 volt
Posted by Paul in Mich on August 26, 2004 at 19:22:14 from (66.188.26.29):
In Reply to: Farmall Super A ? change 6 to 12 volt posted by Myron Schmidt on August 25, 2004 at 22:02:43:
Myron, The biggest reason that most people have a hard time starting a tractor on a 6 volt system is that the cables have been replaced with undersized cables. If you use 0 or 00 gauge cable both positive and negative from the battery, you should have no problem at all starting your tractoreven in sub zero weather. If you do experience starting problem
s, it can usually be traced to another problem.
Post a Followup
Subject:
