Re: farmall H trans.
Posted by captaink on August 27, 2004 at 10:04:14 from (66.115.212.249):
In Reply to: farmall H trans. posted by Jpaustin on August 27, 2004 at 09:56:18:
Did you replace the spring and ball that hold the shift fork in position? If not, that is a place to start. While you have the cover off, check how rounded the teeth are on the gears. If they are rounded too much, the pressures between them will always try to walk them apart, popping them out of gear. LOL.
Post a Followup
Subject:
