Re: Carb problems
Posted by The Red Baron on August 29, 2004 at 11:33:24 from (207.46.238.138):
In Reply to: Carb problems posted by ffolkes on August 29, 2004 at 10:20:26:
Definitely sounds like a float problem. 1)Make sure it is set properly. 2)Take the float off and rattle it to make sure there is not some gas that has leaked in through a hair line crack and is causing the float to sit way too low once you gas it up. (This happened to me once--a great source of frustration and consternation) 3)Examine your needle and seat to ensure that it is not so badly corroded that it is not shutting off properly and allowing far too much gas into the system.
My money is on a float problem.
Post a Followup
Subject:
