Brake question on IH 274
Posted by Jerry Ward on August 30, 2004 at 10:17:09 from (165.215.30.247):
I got a 274 (Offset diesel row crop) running last night for the first time in almost a year. Nothing really wrong, some kind of fuel restriction in the valve coming out of the tank. So I drained out all the old diesel, cleaned out the valve, changed the filter and after several almost starts in was running good. However I stepped on the brakes and the left side stayed engaged. The brakes are hydraulic and the pedal now goes down with no resistance. Is there some kind of parking brake that is set or do I have something stuck in the brake circuit?
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
