Re: Super MTA p.s. pump help needed!!!
Posted by BIG JOHN on August 30, 2004 at 18:35:27 from (152.163.253.103):
In Reply to: Super MTA p.s. pump help needed!!! posted by MarkinIN on August 29, 2004 at 18:51:13:
You DO NOT need a pump. You can use the live power on your SMTA to power the power steering and do away with the aux pump. You will need a power divider valve in the system and you will be good to go.
My SMTA had the same set up as yours and also the same problem. I took the pump, pully, reservior and hoses off and replumbed the hydraulic lines from the live power and put a power divider valve in the system and it works perfect. You will do away with repair and maintance or replacement of the old pump.
Post a Followup
Subject:
