Re: Explain what a cutoff is
Posted by Jim Becker on September 01, 2004 at 20:17:37 from (4.29.47.118):
In Reply to: Re: Explain what a cutoff is posted by Stan(PA) on September 01, 2004 at 13:10:44:
Not bad.
The tire companies had fixtures that you mounted the wheel on. They had a rotating clamp that held the torch so it would swing in a perfect circle. If you knew what you were doing, you could make a pretty true conversion.
Post a Followup
Subject:
