Re: Worn governor gears
Posted by Bob on September 04, 2004 at 07:44:32 from (66.163.134.177):
In Reply to: Worn governor gears posted by Tom Williams III on September 04, 2004 at 06:51:14:
The worn gears, while certainly not a good situation are probably NOT the reason for poor governor response. Check that the governor weights pivot freely without too much play in the pins. Make sure the "fingers" on the weights that contact the thrust bearing are in good condition, without obvious wear, or a "flat spot". Make sure that the little needle (or ball) bearing thrust bearing is in good shape, and all parts are present there. Look at the diagram: (parts key #24 and #25) http://www.cleancomputes.com/Cub/A%20-%20B/TC-26E%20Parts%20Catalog/Page%2032.jpg Is the spring in the governor the correct one, and is is it good condition (not severely rusted, or stretched)? Make sure the linkage from the carburetor to the governor is properly adjusted. Basically, the carburetor butterfly shaft should reach it's "wide open" stop just before the governor lever reaches the end of it's travel in the open throttle direction. A clogged air intake system, bad spark plugs, spark plug wires connected out of the correct firing order, clogged fuel screen, or carburetor problem can also make the engine have a lack of power, and make it seem like the governor is not doing it's job, as can late ignition timing. Also, these tractors are not "powerhouses" under the best of conditions. Are you mowing grass taller than what the machine can handle? Are the blade(s) sharp and correctly installed?
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
