Re: H farmall modification
Posted by Harold H on September 05, 2004 at 03:36:52 from (64.12.117.22):
In Reply to: H farmall modification posted by Walt in Mo. on September 04, 2004 at 14:39:34:
You have to get a reversable transmission top which has the reversed shifter forks. You remove your old top, flip the differential, and install the new top with the reversed shifter rails. Check some of the southern salvage yards. You want a reverse top that was used on low drum cotton pickers. Should not be too hard to find. When you make the conversion, if your tractor is a tricycle, also be sure and turn the steering bolster around to reverse the caster so it will steer right.
Harold H
Post a Followup
Subject:
