Re: Noise in the rear axle of Super A
Posted by lee on September 06, 2004 at 07:55:29 from (24.24.95.246):
In Reply to: Re: Noise in the rear axle of Super A posted by Hugh MacKay on September 06, 2004 at 07:29:45:
I would just like to second the motion to be VERY CAREFUL running the machine on blocks. The wheels are quite heavy, especially if weighted, imbalance, bent rims, loaded tires can offer up surprises.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
