Re: Re: Re: F-20 clutch removal
Posted by George Mikesell on September 06, 2004 at 23:56:20 from (209.42.79.178):
In Reply to: Re: Re: F-20 clutch removal posted by TMAC on April 25, 2001 at 13:39:49:
To answer your question,remove bell housing bolts and coupler, clutch rod and all should come out with no more work. That is provided you don't have a mouse nest or water has gotten into clutch if one or both of these have occured, you have a lot of work to do. I have had this problem and some times I can get most of nest and rust dug out through timing hole. But in severe cases after soaking with penetrant, and heating have had to cut jack shaft with torch and get another. Best advice is see if mouse nest, if so ddig out as much as possible and spray penetrant through cover plate at bottom of housing and heat. If rust, penetrate and heat. When prying bell housing pry on both sides at time to prevent breakage and warping. Also have had jackshaft rust to pilot bearing this can be as difficult as rust and mouse nest. This can take quite a while so be patient,by taking it slow and easy you should get there.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
