Re: Hydraulic pump output of 350 Utilty
Posted by Unreserved dick on September 08, 2004 at 18:35:57 from (4.228.36.138):
In Reply to: Hydraulic pump output of 350 Utilty posted by Andrew McLeod on September 08, 2004 at 18:10:29:
The original specs for the 300/350 distributor-mounted hydraulics (both Farmall and Utility) were 10 GPM with the safety relief between 1200 and 1500 PSI - this may be different with your now almost 50-year-old tractor. The original hydraulic systems on these were not really set up for use of non-IH control valves; the system uses a third circuit in the control valves to load/unload the pump. This is different from most newer tractors. What you want to do may not be very straightforward.
The serial number plate is located on the right side of the tractor between the oil and fuel filters. The number you gave looks like an IH part number.
Hope this is helpful. Let us know if you have more questions.
Post a Followup
Subject:
