Re: Farmall H hand crank?
Posted by Roger WI on September 08, 2004 at 20:29:35 from (69.58.150.217):
In Reply to: Farmall H hand crank? posted by BobinOhio on September 07, 2004 at 17:23:55:
Bob, I just had mine all apart on my H about a month ago. The whole crank assembly can be removed without taking the bolster off the tractor. There is a pin (the spring side) under the sleeve over the part that engages into the crankshaft. That sleeve can be really rusted to to that big shaft after years of mud and radiator leaks. I had to pound on mine a lot to get it to slide back to expose the pin. Once you get that pin out, there is a cotter pin in the shaft that comes out the front of the tractor. You need to remove that so that shaft can be pushed out making room for the big shaft to slide out. Of coarse you have to remove the bottom sheetmetal cover (if there is one there) to get at all this mechanism. Once you get it apart you can either try to grind out the slots or get a different one at a tractor salvage yard (I doubt there are new ones available). You probably should replace the pin connecting the two shafts as mine was really worn. I just cut a bolt the same length as the existing pin. I hope I discribed it OK. Roger
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
