Re: IH 560 D seems stuck in gear
Posted by RN on September 10, 2004 at 04:20:42 from (166.126.218.245):
In Reply to: Re: IH 560 D seems stuck in gear posted by minnimolineman on September 10, 2004 at 00:30:23:
Two gears engaged happens rarely- badly worn sloppy levers and forks causes this when shifting gears-stays in one gear partially and partial engages another -shift lever usually then has hopped out of slider slots, tranny locks. Check pulley plate for full access?-not sure on 560 if enough room to work lever back in, M gears can be slipped back/forth with bar but shift lever needs top cover off to reset. Side plate off should give fair view of shift misalignment/wear. RN
Post a Followup
Subject:
