Re: Farmall M's Gas Hog's
Posted by The Red on September 12, 2004 at 12:55:27 from (12.74.54.170):
In Reply to: Farmall M's Gas Hog's posted by Sean Heywood on September 12, 2004 at 10:57:13:
Depends on what you are using them for. I have both Hs and Ms. If you have a the same sickle bar mower on both the H and M, the M will roughly use 25% more fuel. If you are running a field or bin augur, again the M will use 25% more fuel. If you have a 2 bottom plow on an H and a 3 bottom on the M, the M under load will use up to 50% more fuel BUT you are plowing 50% more at the same time. Per acre fuel costs would be about the same. Same would apply to discing with the H pulling a 6 footer and the M pulling a 9 footer.
Post a Followup
Subject:
