Re: Problem with touch control
Posted by scotty on September 13, 2004 at 09:34:00 from (199.231.49.128):
In Reply to: Problem with touch control posted by Sam in NJ on September 13, 2004 at 05:29:03:
Sam,
I agree with Peabody, I bet your loosing that fluid through your pump, its going into your timing cover and then to the oil pan. You need to disassemble that pump and install new o-rings. You will also want to inspect that pump shaft, if the spot were that o-ring rides has a groove worn in it you may have to replace that shaft also.
scotty
Post a Followup
Subject:
