Re: Calcium filled rear leaking at stem...
Posted by El Toro on September 14, 2004 at 07:24:21 from (216.148.246.70):
In Reply to: Calcium filled rear leaking at stem... posted by FC on September 14, 2004 at 07:00:53:
Hi, I do not think there's a special valve core used with tires filled with calcium. I had mine filled at a local IH dealer. I would raised the
tire off the ground and rotate the tire until the valve stem is at the top. I would release any air pressure and then install a new valve core.
I had a leak in one of my tires and it was the
tube, they had to remove the calcium so they could
remove the tube and repair it. You're right about
not wanting that solution rusting your rim. Good Luck, Hal
Post a Followup
Subject:
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
