Re: Hard starting Super M cont.
Posted by Bob M on September 14, 2004 at 10:39:44 from (165.170.128.66):
In Reply to: Hard starting Super M cont. posted by Ludwig on September 14, 2004 at 10:10:47:
If the tractor runs OK once it’s started it’s not probably not a valve adjustment problem (it would run crappy otherwise). More likely it’s either carburetion or ignition problem. A couple tests you can run:
1 – Pull the air cleaner gooseneck off the carb inlet. With the choke open (rod pushed all the way in) and the throttle open ½, fire a 2 second or so shot of ether into the carb while the engine is cranking. If it fires right up, it’s a carburetion problem. If it does not start or if it spits out the carb or exhaust suspect the ignition.
2 – Pull off one plug wire, attach a fresh sparkplug to the end and lay the plug on the coil. Now crank the engine and watch the gap at the plug. You should see a juicy, blue spark every 2nd revolution. If you get a lazy yellow spark, intermittent spark or no spark at all your ignition system needs work.
BTW a properly tuned Super M is one of the best starting tractors every made. Mine can sit outside for months in sub-freezing temperatures, yet lights off every time after only 2 or 3 crankshaft revolutions.
Post a Followup
Subject:
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
