Re: Farmall H distributor problem
Posted by Bob M on September 15, 2004 at 05:37:05 from (165.170.128.65):
In Reply to: Farmall H distributor problem posted by Red Dread on September 15, 2004 at 04:49:46:
Another possiblity is the camshaft drive gear hub worked loose or broke. That'll mess up the valve timing and will cause a backfiring or "no run" situation just as you describe.
Pull the distributor base from the engine and peek inside at the cam gear. If you can move the gear at all with your fingers you found the problem.
Post a Followup
Subject:
