Re: 666 weak hydraulics?
Posted by El Toro on September 15, 2004 at 08:10:03 from (216.148.244.70):
In Reply to: 666 weak hydraulics? posted by Stick on September 15, 2004 at 01:14:14:
Hi Stick, I would put a calibrated gauge on that
pump to check that hydraulic pressure. An IH dealer can give you the recommended pressure. That bucket should pick up 1400 lbs. Can you swap hydraulic lines from the bucket side to the
tilt side of the control valve? Hal
Post a Followup
Subject:
