Re: 666 weak hydraulics?
Posted by IH Rob on September 15, 2004 at 10:33:40 from (156.101.1.5):
In Reply to: 666 weak hydraulics? posted by Stick on September 15, 2004 at 01:14:14:
Once you get the bails lifted, does the loader drift back down? If so, you may have a bypassing hydraulic cylinder. If all other functions are OK, and the load stays lifted once it's up, you may want to check and see if there is a "port relief" valve on that particular section of the main operating valve. I have seen some loaders set up with it to limit the amount you can pick up. It's always set lower than the main relief valve. I'm new to farmimg, but I do know a little about hydraulics. Just my two cents worth. Hope it helps. ROB
Post a Followup
Subject:
