Re: IH Farmall 350 diesel - brake question
Posted by Bob M on September 16, 2004 at 08:29:47 from (165.170.128.66):
In Reply to: IH Farmall 350 diesel - brake question posted by marshallpa on September 16, 2004 at 07:55:40:
Farmall disk brakes like your 350 has are quite different from automotive (caliper) disk brakes. Each brake assembly consists of a pair of rotating brake disks splined to the differential output shaft. These disks have the friction material bonded to them. In between the brake disks sits an actuator assembly consisting of a pair of cast iron disks. The whole business is then sandwiched between the cast iron brake cover and the side of the transmission. In operation, the brake pedal causes the actuator assembly to expand (thru balls and ramps between the actuator disks) when the pedal is depressed. This squeezes the friction discs between machined surfaces on the actuator disks, the inside of the brake cover and the side of the tranny causing the braking action. Many people bad mouth Farmall disk brakes. However properly maintained they work great and last a long time. But they are extremely sensitive to contamination from leaking tranny lube, rainwater infiltration, lack of lubrication of the shaft splines/actuator disk balls, improper adjustment, etc. Also a set of 4 new friction disks (2 required on each side) will run close to $100. Hope this helps...
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
