Farmall Tractors Discussion Board
Re: Magneto timing on H
Posted by Mark on November 11, 1999 at 21:51:57 from (209.166.185.71):
In Reply to: Magneto timing on H posted by Dennis(WA) on November 11, 1999 at 13:31:21:
Sounds like you're a tooth off on the timing. Set #1 cyl on the compression stroke with the pointer lined up with the timing mark on the crank pully. Take the mag off, noting which way the rotor button is pointing, turn the mag opposite the direction of rotation just enough so the mag driven gear will mesh with the cam gear one tooth advanced from where it is now. Bolt things back up and do the fine setting with your timing light.
Post a Followup
: Re: Re: Magneto timing on H
