Re: How hot to heat crank pulley??
Posted by EZ on September 16, 2004 at 19:10:00 from (216.211.7.79):
In Reply to: How hot to heat crank pulley?? posted by RT (seTX) on September 16, 2004 at 17:44:56:
It does not hurt to heat the pulley up some, but you don't want to get it boiling. I've been doing bearings in a pot of oil, heat it , but don't boil it. You don't want to damage the seal with too much heat either. Heat it up some and the oil will also help it sliding on, you will most likely have to help it near the end. Will you be using a threaded rod in the end of the crank to help push it on?
Post a Followup
Subject:
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
