Re: Removal of cam gear on H
Posted by El Toro on September 23, 2004 at 04:17:25 from (216.148.246.134):
In Reply to: Removal of cam gear on H posted by MagMan on September 22, 2004 at 18:30:01:
Hi Jon, Is the gear thick enough to drill and tap threads? If is then you could use your gear puller and keep using that torch to apply heat.
Good luck, Hal
Post a Followup
Subject:
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
