Re: OIL pressure on rebuilt motor
Posted by Allan in NE on September 23, 2004 at 17:41:16 from (148.78.243.24):
In Reply to: OIL pressure on rebuilt motor posted by Bill from Seneca ,IL on September 23, 2004 at 17:24:27:
Hi Bill,
For the most part, oil pressure is determined by pump, crank bearings, camshaft bearings and their connecting passages.
Doubt if your head workings has much to do with the pressure issue unless you have a massive leak at a feeder line or some such thing. But, that would probably show up cold as well as hot
Now, in reality, an engine really only needs about 8 lbs of true oil pressure to operate without eating itself up, but we always like to see 'er up there around 30lbs or so when hot.
Some manuals will tell you that bearing oil clearance can be considered "okay" if it is as high as .003"; some of these young hot rodders even run their engines with a clearance of .005".
I always set mine right at .0015" (minimum clearance is considered by most builders to be at no less than an absolute .001"). Never had an oil pressure issue yet and I've built a trainload of engines.
Just my view,
Allan
Post a Followup
Subject:
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
