Re: farmall 806
Posted by K.B.-826 on September 23, 2004 at 18:54:11 from (209.163.30.65):
In Reply to: Re: farmall 806 posted by john in ohio on September 23, 2004 at 13:50:00:
One problem is the shift pattern itself. You have to shift through low every time you want to go from high to reverse. The fix there is to install a 56, 26, or 66 series shift kit. Costs about $500 and takes a little work, but is so much nicer. The 56, 26, and 66 sereis tractors had high, low, and reverse laid out in an h-pattern. Now, on the grinding. They will all grind if you don't take the time to shift them. The proper way to do it is to start out with a properly ajusted clutch, TA, and transmission brake linkage. When shifting the Range Transmission (high, low, reverse), you must come to a complete stop. Push in the clutch pedal about 3/4 of the way and apply the brakes. Then, push the clutch pedal all the way down to engage the transmission brake. Now shift. You don't need to worry about all of this when shifting the Speed Transmisson (1-2-3-4), with a little practice, you'll be able to shift those gears on the move without grinding.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
