Re: H generator info
Posted by Bob M on September 24, 2004 at 05:06:25 from (165.170.128.66):
In Reply to: H generator info posted by Rock2000 on September 23, 2004 at 16:58:21:
Sounds like you have a good working generator but messed up wiring and a bad 6 volt battery. Here's what I'd do:
1 - Buy a voltage regulator for a late model H (about $35 at TISCO, etc).
2 - Wire up the regulator per the diagram below. (Regulator will take over the function of charge control from the light switch).
3 - Install a new 6 volt battery.
You will end up with a system thats easy on the battery and which will keep it charged.
Post a Followup
Subject:
