Re: H or a C ?
Posted by ed1 on September 24, 2004 at 06:54:58 from (198.185.163.6):
In Reply to: H or a C ? posted by terryj on September 21, 2004 at 23:37:36:
Forget about the belly pump as everytime you push in the clutch your hyd's will stop. Go with live hyd's. The hyd pump that goes in between the distribuitor and engine is $700 or $800 and still available.
Everyone I know of unhooked the drive coupling on the belly pump and simply used them as a hyd oil tank years ago.
The C is in more demand than the H and will bring higher $$$$
Both good tractors.
If your thinking about a H I would step up to an M. Frame size is not close and HP is higher
Post a Followup
Subject:
