light switch conections on 1942 H
Posted by JRB IN MAINE on September 24, 2004 at 17:34:24 from (24.198.78.55):
I got a new volt meter today and hooked it up and I ran a new wire from the L side of the regulator to the switch . the old hook up went from the switch to the right side volt meter .Hooked up that way the volt meter shows discharge and if hooked from L side of regulator it shouldn"t There is another coil conection at the bottom of the switch that I dont no where it hooks to.when I restored and rewired the tractor the wires were all striped bare and conections were rotted off so I dont know were it hooks to. well sence my hook up I have found the coil at the top smokes if you only put the switch for just headlights but dosen"t if all lights are on . is that missing conection a ground or that . that do you think ?
have no digriam to go by when I wired the tractor I used a digriam to a farmall c manaul. the H manaul I have dosen"t show anything. does anyone out there know ? Thanks Jeff
Post a Followup
Subject:
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
