Re: ? About 300 Or 300 utility motor parts.
Posted by DWV on September 25, 2004 at 17:09:39 from (205.188.117.22):
In Reply to: ? About 300 Or 300 utility motor parts. posted by MagMan on September 25, 2004 at 12:47:06:
If you want to run exhaust up through hood they
will interchange.Some of the aftermarket manifolds
have slotted carb mounting holes so both carbs will work using bolts.
Post a Followup
Subject:
