Farmall Tractors Discussion Board
Re: Re: Re: white-blue smoke from diesel TD-6
Posted by Dennis on November 13, 1999 at 17:27:35 from (206.159.43.36):
In Reply to: Re: Re: white-blue smoke from diesel TD-6 posted by RUSS on November 13, 1999 at 15:15:25:
No, it has not been using oil. Water level seems to stay the same also. There is no water in the oil, or oil in the water.As for water pump lube, there is a grease fitting on the TD-6 for that. Thanks
Post a Followup
: Re: Re: Re: Re: white-blue smoke from diesel TD-6
