Farmall Tractors Discussion Board
Re: Re: white-blue smoke from diesel TD-6
Posted by RUSS on November 13, 1999 at 15:15:25 from (204.221.240.3):
In Reply to: Re: white-blue smoke from diesel TD-6 posted by Wayne on November 13, 1999 at 04:38:10:
I would definitly try some stop leak, it's also a great water pump lube! You didn't say if it uses any oil, the blue smoke sounds like oil or a bad injector.
Post a Followup
: Re: Re: Re: white-blue smoke from diesel TD-6
