Re: Farmall 544 utility
Posted by CNKS on September 26, 2004 at 11:18:21 from (207.178.99.81):
In Reply to: Farmall 544 utility posted by Chad L. on September 26, 2004 at 07:08:53:
The tractor is ok for your intended use, perhaps a bit large for only 5 acres. It should easily handle a three bottom plow, a 4-row planter is no problem. It does not have a lot of clearance, which means you wouldn't be able to do late cultivation, but depening on your weed situation that may be ok. Calcium chloride is hard on rims if it leaks, otherwise you can use wheel weights for snow.
Post a Followup
Subject:
