Re: 1 Point Fast Hitch
Posted by Sharky on September 26, 2004 at 18:27:30 from (65.24.194.155):
In Reply to: Re: 1 Point Fast Hitch posted by Hugh MacKay on September 25, 2004 at 18:30:42:
Het, Hugh,
I went out and measured by 140 Fast Hitch points vs. the Cub Fast hitch points. I found no difference. I re-read you reply, and think I measured the wrong demension, so When you say they are an inch Difference, you don't mean thickness, (Wide) side to side, but rather thickness top to bottom? Right? (Than's the only demension I didn't compare) Everything else measured the same, Point size, groove length, point length, width 1" (side to side), so If I understand you right you would put to plate you're refferring to on the bottom of the Cub Fast hitch point to make up the difference?
Post a Followup
Subject:
