Farmall Tractors Discussion Board
Re: Re: white-blue smoke from diesel TD-6
Posted by Farm-Al on November 13, 1999 at 19:38:03 from (167.142.19.45):
In Reply to: Re: white-blue smoke from diesel TD-6 posted by Wayne on November 13, 1999 at 04:38:10:
One thing I might suggest would be timing. You might try changing the timing A slight amount but be sure to note where you start from and go from there.Try unhooking the air cleaner this may also be A sorce of smoke due to either being paritaly plugged or pulling oil into the intake. Outher than this, checking the nozzles and pre cups may be the next step,be sure the pump crankcase is not full of diesel fuel which can be the death of the pump. Good Luck
Post a Followup
: Re: Re: Re: white-blue smoke from diesel TD-6
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
