Farmall Tractors Discussion Board
Re: white-blue smoke from diesel TD-6
Posted by Wayne on November 13, 1999 at 04:38:10 from (209.240.197.38):
In Reply to: white-blue smoke from diesel TD-6 posted by Dennis on November 12, 1999 at 20:29:49:
This sounds interesting. Could do a compression check after it is good and warm and see what the results are. It is normal for a diesel to smoke white on start up. If they smoke white when warm it is usually water in the cyl. Blue smoke is oil consumption. These engines have been known to crack heads. If you are lucky maybe just a head gasket. I'm not a mechanic by trade. Could try this. Get a tube of Silver sealer and put in radiator and see if this cures the problem. Cost is about a buck and half. Good luck
Post a Followup
: Re: Re: white-blue smoke from diesel TD-6
