Re: Farmall Super C with leaking tom water spout
Posted by achodges1 on September 27, 2004 at 20:52:48 from (65.179.200.186):
In Reply to: Farmall Super C with leaking tom water spout posted by Scott Swanson on September 27, 2004 at 09:38:16:
If you have a working temp gauge you can run without a cap. You will still need to check and add water often. and antifreeze as well depending on conditions. JB weld might be a cheap fix for the neck.
Post a Followup
Subject:
