Re: hydraulic oil or motor oil for the pump
Posted by Nebraska Cowman on September 28, 2004 at 05:32:17 from (65.162.146.119):
In Reply to: hydraulic oil or motor oil for the pump posted by cj on September 28, 2004 at 04:59:24:
That is the old way but I would use Hy-tran. Modern hydraulic oils were not available when the lift-all pump was designed but are a much better substitute now.
Post a Followup
Subject:
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
