Re: Magneto's
Posted by MagMan on September 28, 2004 at 16:30:23 from (64.12.117.22):
In Reply to: Magneto's posted by Steve M on September 28, 2004 at 15:45:52:
I dont like to give away the trade secretes but.
Alls you have to do is if its removed lay it on the RH side looking at the trip take the wire out of the distributor cap and hold it about 1/4 " away from the screw on the side that the switch wire would hook up to and give it a trip or spin the opisite way also and if its good you should see a spark at the wire end. Color depends on coil, points cleanlyness and so on.
HOPE THIS HELPS JON
Post a Followup
Subject:
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
