Re: Magneto's
Posted by Bob M on September 28, 2004 at 16:32:54 from (66.67.13.141):
In Reply to: Magneto's posted by Steve M on September 28, 2004 at 15:45:52:
This is "quick 'n dirty" test that works for me:
1 - Pull the center wire out of the mag distributor cap. Plug it onto a good spark plug.
2 - Lay the mag on it's side on a bench. Then lay the plug top of the mag so the plug shell is touching the metal mag housing.
3 - With your fingers quickly spin the mag drive coupling clockwise 1/2 turn at a time (you gotta spin it fast so the impulse doesn't catch).
If the mag is good you will get a blue spark with every half turn of the coupling. (You will feel a "bump" in turning resistance at the point where the mag "fires".)
This will verify the high voltage section of the mag. To test the distributor part:
4 - Put the center wire back into the distributor cap.
5 - Take a second plug wire and stick into any of the remaining cap towers, then place the other end on the spark plug like before.
6 - Repeat the spin test above. You should get a spark once every TWO revolutions of the drive coupling.
A word of warning: Do this only with dry hands! If you are at all sweaty, the mag is good and finger is in the wrong spot you run a good chance of being knocked on your a$$ when the mag fires...trust me!
Post a Followup
Subject:
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
