Re: Thanks! follow up: Bigger than an M, one for h
Posted by Carp on September 29, 2004 at 14:28:41 from (12.27.55.243):
In Reply to: Thanks! follow up: Bigger than an M, one for her! posted by Adam Paul on September 29, 2004 at 13:12:16:
The drop axles on an MV do not use a bull gear to get the axle drop. There is a chain drive in the drop potion of the axle so the tractor goes the same direction and speed as it was originally designed. You can put the drop axles and single wheel front end from a cotton picker on anything from an M to a 560 I believe.
Post a Followup
Subject:
