Re: IH 6 Cyl. Diesel won't start
Posted by K.B.-826 on October 02, 2004 at 19:35:40 from (209.163.30.67):
In Reply to: IH 6 Cyl. Diesel won't start posted by Ibby on October 02, 2004 at 16:14:55:
Did you bleed it all the way up to the injectors? Crack the lines at the injectors loose and crank it over until you get fuel spraying out at each fitting, Then tighten the fittings back up, and it should start. Like the other guys say, sure would help to know what engine you've got. I wouldn't go pulling out injectors yet, or dumping oil in the cylinders (bad, bad, idea). Take it easy on the ether.
Post a Followup
Subject:
