Generator working?
Posted by GeorgeH on October 03, 2004 at 15:38:21 from (67.241.9.11):
1946 H recently acquired without all wires hooked up on generator. Took care of that problem and polorized.
Resting voltage is normal, when running with voltmeter across battery terminals jumps mostly 12+ to 13+ but sometimes drops to 8 volts. Sound normal or a problem?
Tractor is converted to 12 volt battery with appropriate distributor ignition changes. I am of belief generator and regulator are factory original (kinda think remainder of tractor might be also).
Any thoughts ?
Post a Followup
Subject:
