Farmall Tractors Discussion Board
Re: Re: 2 way hydraulic system for an H
Posted by Larryg on November 14, 1999 at 18:55:26 from (165.87.14.12):
In Reply to: Re: 2 way hydraulic system for an H posted by Tractor Tim on November 11, 1999 at 07:28:13:
.....that won't be a "live" system because the pto is driven through the tractor clutch so when you throw out the clutch, the pto pump will stop, but it will work. Don't forget the resevoir for the hydraulic fluid, filter for the pump, etc. To be a live system, you have to drive the pump off the engine in front of the clutch.
Post a Followup
: Re: Re: Re: 2 way hydraulic system for an H
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
